Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1004 Questions View all
Is it possible to transfer my photos and videos from my old MacBook 17
A funeral director dropped my MacBook Pro and it never worked since.
I have so many precious irreplaceable photos and iMovies on it. Is it possible to send it in to a specialist to have it transferred?
The Apple Store said they couldn’t do it.
Add a comment
Most Helpful Answer
Is the system not responding at all? Or, has the drive its self failed? Sometimes we can still get the system to startup enough so we can recover the data.
You’ll need a second mac (one that has a FireWire port) to try to gain access to your systems drive using Target Disk Mode.
Here we are starting the system up and pressing the T Key to enter into this special condition. Once its in this state we can treat your system as if it where an external drive connecting it via a FireWire cable to your other system. Then you can just copy off your stuff. Reference: How to use and troubleshoot FireWire target disk mode
If that doesn’t work you can take your drive out and using a SATA to USB adapter cable connect it to your other system StarTech 2.5" SATA to USB adapter cable
If neither of these methods work you’ll need to ship your drive to a data recovery service to fix your drive enough so the data can be recovered. Drive Savers. Depending on the how bad the drive is damaged they may not be able to recover everything and I’ll warn you it is not cheap!
Once you get your stuff recovered and you have a new system you will want to make sure you have an external backup solution so you don’t need to go this far.
Score 1
Add a comment
Edit: Removed post because I thought this was one of the MacBooks that come with SSDs.
2 Comments:
@benjamen50 - Hard Drive here, drive may have crashed!
by
Oh yeah my bad, this is probably a unibody model which has a hard drive by default.
by
Add a comment
Add your answer
crazeeabigail will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 30
