Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Proximity sensor troubles (Works sometimes, sometimes not)?
Hi,
i've already read the related answers but that doesn't adress my problem. As i stated, the sensor sometimes switches the screen off during a call sometimes not. Hard reset didn't help. The phone was never dismanteled, but has had a hard life (well i use it a lot).
iOS 4.1 (8B117)
Modem Firmware (Baseband) 06.15.00
jailbroken and unlocked.
Any idea?
Add a comment
1 Answer
Chosen Solution
My first guess would be that it's because you have the iPad baseband (6.15.00) installed. Though the dev-team says it's perfectly safe to use, it can cause all kinds of things to go wrong. I would consider looking around on Cydia for a tweek that disables the sensor all-together, or update the phone to a newer version of iOS (If you have saved SHSH blobs) and see if that resolves the problem.
Score 3
1 Comment:
Thanks - i reseach into that direction. I'm a bit careful though, because the phone works fine otherwise and i don't want to loose my unlock. +
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,539
