No power or power light
samsung model J6200
I don’t have any sort of power, switched outlets etc. Did my board burn up?
samsung model J6200
take a look around D901 and T9101C etc., your board has a shortcircuit around that area. You can make out the charred diode and the board itself. all the signs and symptoms you describe point to a bad power board. Replace the board and re-evaluate
Oof, I didn't even see that in the picture. That's definitely part if not all of the problem.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 57
2 Comments
Sometimes it's really hard to tell that the display panel is turning on. I have a Samsung TV that needed new led backlights, and it took the strongest flashlight I had to tell that the display panel was working. I'd recommend looking over the whole screen with a super bright headlamp or flashlight while the TV is on and see if you can make out stuff on it.
One way to determine if it's a dead control board or not is whether the TV makes sounds or responds to the remote.
by Alec M
The Tv would not respond at all. The red power reserve light was also out. It seems to be completely dead, that’s a small burn mark, but I haven’t tested the fuse yet (due to not having the correct tools)
by James
