2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
Will it work? Swamping SSD's move from one MacPro to Another?
Can SSD’s between 2 different Macs of similar model and era be swapped? In doing so, does each function as the other did prior to the swap without any extra programming?
If so, do the serial numbers remain with the original units?
Update (03/09/2019)
Thank you so much. But, if I swap SSD’s on like machines, doesn’t the operating system also go with, rendering the need to install an OS unnecessary?
1 Comment
@newtomac If you swap the drive the new one won't necessarily come with the OS already installed, it might be just formatted. However, that's no reason for concern, a new OS may be downloaded and installed with just an internet connection and few easy steps: https://support.apple.com/en-ke/HT204904
by
Add a comment
Chosen Solution
Serial number belongs to the logic board, whatever other part you may replace won’t change that. Retina Macbook Pro kept the same 12+16 pins SSD from mid 2013 through 2015. You could as well swap with a Macbook Air Ssd of the same time period, they are just the same. You won’t need any special programming, only the operative system needs to be installed.
Score 2
Add a comment
Yes you can do a swap for the same model and year, functionality is still.
The serial don’t remain the system will read the new macs where you install your SSD.
Score 1
2 Comments:
Thank you for the response. Please clarify answer "The serial don’t remain the system will read the new macs where you install your SSD". - does this mean the serial number moves with the SSD to the purchased machine or it remains with the system from which the SSD came? Thanks again
by
The serial don't remain in the system or in SSD , you can move your SSD in any mac because the system will always read serial of a mac where you put your SSD..
by
Add a comment
Add your answer
Dean will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 100
