2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Keyboard and bottom case replacement options.
I have a 2009 Macbook Unibody (white) and was wondering if I could replace the stock keyboard with a Macbook Pro keyboard, so I have black and backlit keys. You know, just to spice up the computer a little bit. I was also wondering if since the bottom case’s rubber is so worn if I could get an aluminum Macbook Pro bottom case and put it on this? Would it fit? Are some components protruding too much for it?
Add a comment
1 Answer
Not possible. The circuitry for keyboard backlight is missing for it to be compatible, also it is physically different to fit in.
Add a comment
Add your answer
Hyrum Tripp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 102
