15% Off Selected iFixit Tools — Limited Time
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
Front camera flex cable issue
While removing the flex cable with heat the cable separated (not broken) from the other part. It had a little bit of glue. Between both sides it has tiny pins that I guess are supposed to be in contact to work. Camera works but proximity sensor not aswell as the speaker. Please let me know if there is no way to put it back together or I'm better of getting a new flex. Thanks in advanced.
Add a comment
Chosen Solution
You could potentially solder the two ends together but the risk is that traces were torn when it broke. When considering the cost of the flex, it’s better just to replace it.
Score 3
1 Comment:
Thanks I thought that was the ideal way to go.
by
Add a comment
If replace not work true tone
Add a comment
Add your answer
TxShack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 1,119
