Repair and disassembly guides for the Jura (Capresso) Impressa Series J coffee maker.
Why is the GFI outlet tripping as the machine makes coffee
The machine turns on and heats up and then turns off mid brew
Score 1
Add a comment
Chosen Solution
Hi @edgewood ,
If the GFI trips mid brew there may be a problem with the heater element in the machine, going low resistance (shorting out) to the earth connection (chassis perhaps) in the machine as it heats up or another component that is “live” during the brew cycle, maybe the thermostat, touching earth.
The machine will need to be opened and the heater circuit tested to verify this.
Here’s a link to the ifixit Jura (Capresso) Impressa J repair guides.
Here’s a link to the Jura 5 parts diagram which may also be of some help.
This link may also be of some help
Score 2
Add a comment
I discovered the GFI was tripping because one of the water hoses on one the heater ports was leaking.  Water was dripping onto the lower end of the brew group motor and the on the wires and electronics at the bottom of the machine.  Once the machine dried out and I reset the GFI outlet the machine would run until the water leaked enough to cause a current leak.  It was not shorting enough to blow my circuit breaker but just enough to trip the GFI outlet.  I hope that helps someone else with a similar problem.
Score 1
2 Comments:
Same problem I think with my Jura Z9. So did you just replace a hose or do something else to repair your machine?
by
Yes replaced broken hose. Problem fixed.
by
Add a comment
Add your answer
Caroline Wolkenstein will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 4,223
