The Asus Vivobook Max X541SA-PD0703X is a portable personal computer maufactured in May2017 by ASUS.
6 Questions View all
Very Slow with only 2GB RAM onboard Asus Vivobook max X541SA
This laptop only has 2GB RAM onboard, is it possible to increase this and how?
Score 1
Add a comment
Chosen Solution
Yes. Up to 8 GB SDRAM , DDR3L 1600MHz SDRAM Onboard Memory
The RAM slot is on the under side of the motherboard!
Score 1
3 Comments:
Hi @aactech ,
It appears as though not all 541 models are the same.
I posted a video earlier showing the 541 UV RAM replacement and as you stated the slot is on the back of the motherboard.
When corrected by the OP that it was not the same as theirs I posted one of a 541SA teardown and there is no sign of a RAM slot on either side of the board.
In the video, to me there are signs of the RAM being soldered directly to the board, but hey. my eyes aren't what they used to be.
Cheers.
by
Your eyes are fine and I think our friend the soldered on RAM.
by
Sorry but you are out of luck. You have the “rip off” model.
I’m guessing it is a “Chromebook” for school children.
by
Add a comment
Most Helpful Answer
Hi,
It seems that you cannot upgrade the RAM in your laptop without replacing the motherboard.
Here's a link to a teardown video for your model showing that the RAM is mounted directly onto the motherboard.
Apologies for the earlier post
Score 1
1 Comment:
This is a different model to mine, mine is the X541SA with 2GB on-board RAM that I want to
by
Add a comment
I know I’m late for the party, but here’s one I opened up recently. Windows 10, 2GB RAM non-upgradeable. Not quite a Chromebook plaything, but rather a cheap piece of junk for Adults who should rather have spent some extra for a proper notebook.
Score 1
Add a comment
You may have to install more RAM, but if you don’t want to, there are still some ways to improve your laptop’s performance by manipulating your computer’s hard drive.
  1. Give your hard drive less work to do. Uninstall software you don’t need, and store your photos/videos/documents/etc. on a flash drive instead of on your hard drive. Hard drives with less data and programs on them run faster.
  2. Optimize your hard drive. HDD hard drives are slow compared to SSD hard drives. If your hard drive is an HDD, running the defrag/optimize utility may help. Type “Defragment and Optimize Drives” in the Search Bar at the bottom left of your screen, hit Enter, and click the “Optimize” button on the window that pops up. Windows will tweak your hard drive for the best performance that is possible for it.
  3. Consider using ReadyBoost. ReadyBoost is a Windows feature to help hard drives that run at 5400 RPM or less. ReadyBoost allows you to plug in a USB flash drive into your computer and have Windows use it as if it were extra memory. To use the ReadyBoost feature, plug a flash drive into your USB port. Then, open Windows/File Explorer and right-click on the flash drive. Choose “Properties” from the pop-up menu and go to the ReadyBoost tab. Click the Use this device option and click OK.
Your computer’s performance should improve.
Add a comment
Ram is soldered onto the mother board.You would have to solder another ram onto mother board .
1 Comment:
Any idea where on the motherboard, I cannot see it, If I can find it I can upgrade it lol
by
Add a comment
Add your answer
swordgroup will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 16
All Time: 4,233
