4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
iPhone SE in bootloop after taking out battery.
I took the battery out of 2 of my iPhone SE’s to replace the powerbutton/volumebutton etc. everything did go nice and smooth as usually. But now they are BOTH in bootloop. I can’t think of any cause.. the only thing I can think of is that I bent the battery’s a bit, because both of the adhesive let loose :(. Could this be my cause? Because then i will just get some new battery’s.
Add a comment
1 Answer
The battery will work fine, even when bent. Severe bands can cause fires, but gentle bends can be flattened out again.
Either your motherboard has a problem, or your power button is stuck. Try with the switch connections disconnected, and connect the phone (off) to your computer running iTunes. It should boot normally, I test motherboards out of case this way.
1 Comment:
It were big bends, anyways i dont think it is the mobo, and iT wont reset through iTunes. Both niet SE’s have the exact dame probleem..
by
Add a comment
Add your answer
Lars will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 53
