Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2266 Questions View all
Battery at 1%, searching for carrier and slow boot
Hi
A while ago I bought an iphone 7 (phone 1) that was used that had a broken screen. When I got it (phone 1) it wasn’t booting as it should, so I took out the battery and tried it in another iPhone 7 (phone 2). When I tried the battery in (phone 2), it (phone 2) wouldn’t boot normal either, and when it (phone 2) booted up the battery only says that it (phone 2) has 1% charge and when the lightning cable is plugged in it doesn’t say that it (phone 2) is charging. It isn’t recognized by iTunes neither. Also (phone 2) only stays at “searching“ on the top left corner (searching for carrier network). It (phone 2) is also really, really slow when in use. (Phone 2) worked as it should before I tested the battery from (phone 1). I have also confirmed that both of the batteries from (phone 1) and (phone 2) work as they should. (Phone 1) won’t recognize any audio device, so I suspect that it (phone 1) has a bad audio IC? But my question here is actually what is wrong with (phone 2) that worked before I tested the battery from (phone 1)? I am thinking that it might be the charging IC, but I am not sure.
Add a comment
1 Answer
Most Helpful Answer
Phone 1 definitely has the audio IC issue.
Phone 2 I would still try a new battery first. Then move onto the lighting port being a possible issue as well because of the searching issue.
Score 3
4 Comments:
I have tried a new battery in phone 2, but that didn't help. What has the lighting port to do with the searching problem?
by
The speakers work as they should in phone 1 also.
by
The lightning port has an antenna in it that connects to the logic board.
by
Try dialling *#06# on the searching phone. If nothing displays and/or IMEI and modem firmware is not present in phone settings general about the phone has a baseband circuit fault on the logic board.
by
Add a comment
Add your answer
Anders Tellefsen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 84
