Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
LCD not as smooth
I added a video..
So this is a 2nd hand item. The screen cannot hold 2 press at the same time and it is not as smooth! its sticking. Tried changing the lcd with the same backplate and still the same! 3d touch is slow too! it’s like it has a default time for press. Should I change lcd or just go get a better model.
+will replace rear and front cam from an abandoned 6s
+yoobao battery or just go sell entirely
-touch id and double tap not working just home button
stressfull lol
Add a comment
1 Answer
Chosen Solution
Hi
is this an aftermarket LCD or an OEM LCD
Thank you
Score 1
2 Comments:
I also have the aftermarket one still the same haven’t tried original lcd attached
by
i would suggest trying an original one if you can get your hands on one. if that also fails then it will be a logicboard issue. but i think the screen is likely the cause of your issue
by
Add a comment
Add your answer
repairwhat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 100
