The HP 15 laptop can be identified by the model number R263DX.
6 Questions View all
How can rid of a black spot on my pc?
Yesterday, i got a little black spot on my pc screen. I don't know why.
And this morning i found out that is getting bigger.
Is there any solution to fix it without the need to replace it.
Add a comment
1 Answer
Occasionally, the pixels on your computer screen will get stuck and you may see a red, blue, green, white or black spot. If you have a LCD computer screen, try to remove the broken pixel by lightly rubbing on it. Otherwise, use a software application to help you to remove it. Software such as Jscreen Fix, Pixel Fixer and Dead Pixel Buddy are designed to locate and fix broken pixels on a your computer screen.
3 Comments:
Actually, i tried Jscreen Fix for about an hour. And nothing special.
by
Hi @dhia1 ,
Just to eliminate the remote possibility that it is not a screen problem, try connecting the laptop to an external monitor and check if its' display is OK
by
@jayeff Ok i will try it later.
by
Add a comment
Add your answer
Dhia eddine will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 20
All Time: 4,768
