2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
cold replacement of the battery
My early 2013 MacBook pro 15” needs a battery replacement. The batteries are swollen. To make removing the battery pack safer, can this be done in cold conditions. I noticed that leaving the MBP outside for a day. The swelling decreased significantly. Will the adhesive remover work in temperature close to freezing?
1 Comment
I haven't tried to remove the battery yet. But one question. Would the dental floss method of cutting through the dissolved adhesive be safer?
by
Add a comment
Chosen Solution
Yep, it may take noticeably longer but will still work.
Add a comment
Good question! While the swelling will decrease as the battery gets colder, the effectiveness of the solvent will decrease as well.
So the trick is keeping the battery cold but allowing the aluminum uppercase to stay at room temp. Using a waterless Ice block you use to keep food cold should offer the cold to keep the battery under control as you allow the case to warm up.
The cold will also prevent the solvent to evaporate as quickly so you want to use less.
I would get a few sets of plastic cards to wedge underneath the battery cells as you free them up. You may need to re-cool your system and attack it again a few times. MacBook Pro 15" Retina Display Early 2013 Battery Replacement
Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417. Image
Product
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
$79.99
Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172 Image
Product
Plastic Cards
$2.99
Add a comment
Add your answer
Joe Pohlman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 217
