Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1200 Questions View all
0.2 inch Light stripe on the screen after dropping my phone
I dropped my phone, the screen didn't crack but I have this light on the side about 0.2 inch. Appended pictures.
Should I change a new screen or it’s a connection issue ? Anyone has any suggestion? thx!
Score 2
Add a comment
Most Helpful Answer
Hey Piper, it is possible that the LCD connection is slightly loose, I would suggest disconnecting the battery, and then reseating the LCD connectors, and then connecting the battery. If this doesn’t work, it is possible the backlight in your display may have been slightly damaged, and will require a new screen to fix. I hope this helps!
Best of luck, Alec
Score 2
Add a comment
Super powaaaa, my mom has the same issue but she calls it her light saber!!!
Add a comment
Hi Piper,
Did you end up figuring out how to fix the light?
I dropped my phone and the screen didn't brake but now I have that same strip of light on the bottom of the screen. Hurts my eyes.
Add a comment
You can damage the LCD and not the Digitalizer, which is what looks like happened. a new screen should fix it.
Add a comment
I have a question my cell phone one day just stop working I cant get it to come back on.so I took it apart and theres a little brown mark on the strip that connects to the back of my screen what does that mean? If anyone could help me out with this that would be great thank u.
Add a comment
Add your answer
Piper will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 92
Past 30 Days: 390
All Time: 26,736
