Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
CPU Panik?! MacBook not booting. Stuck on loading screen. With error
Hey there,
i have a macbook Pro 2010 13” with an Error massege popping up on start up.
It chimes and everythink looks pretty good, but it wont boot up.
I am aware of the 2010 GPU kernel Panic issue but I tought its just the 15” Macbooks. And this seems to be something different?
Thanks for your help. Pease üt-
Add a comment
1 Answer
You have a page fault condition, this is when you either have a RAM or HD problem.
I would take the time to clean the memory module contacts and reseat them. In addition I would reboot under the recovery partition so you can run Disk Utility to check the drive. I would look at replacing the HD SATA cable and the drive with a larger one.
7 Comments:
Thanks for the answer i cleaned the cntacts with alcohol . i am trying to start it from a usb stick. is the image corrupt? Still not working...
by
What is the bootable USB drive doing?
Are you sure it's the boot drive?
by
yes i am trying to run the install from it. and i choosen it via alt on boot
by
the error is not allways displayed most of the time it just freezes
by
Replace the RAM: 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM's
by
Show 2 more comments
Add a comment
Add your answer
Niklas Jakob will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 5
All Time: 231
