The Lenovo IdeaPad 320-15ABR is a perfect consumer grade laptop for the everyday individual.
10 Questions View all
Stuck on lenovo logo and even on system repair
My lenovo ideapad 320 stuck on lenovo logo when turn it on, so search some solution, so i try the oneclick repair and i choose the system recovery and i wait it too load but it just a black screen even i wait for about 1hr its just a blsck screen please i need help all my thesis file are on my laptop.
1 Comment
HI Neil
For Data Recovery , I would suggest you to use Hiren to recover.
Download from another computer and get a thumbdrive.
https://www.hirensbootcd.org/download/
Follow the steps to make the usb thumbdrive bootable
insert the thumbdrive on the laptop and power it on
press F12 (IIRC)
and select boot from thumbdrive
let the OS load and once it is loaded, you can try accessing your current hard disk to recover the files.
it would be good if you prepare an external hard disk beforehand.
I would suggest you to run Lenovo Diagnostics to test your hard disk.
On the PC and keep hitting on F10 to lenovo diagnostic.
From there test your hard disk.
by
Add a comment
1 Answer
Most Helpful Answer
You can still try to perform power drain without removing the internal battery of your laptop just follow the steps below.
- Turn off the laptop
- Remove the charger
- Remove any accessories like USB flash drive
- Press and hold the power button for at least 10 seconds
- Then re-connect the charger on your laptop and power it on
Possible that there's a corrupted system file on the laptop that is why it no longer boot to Windows. You may try to perform a System Restore if you a restore point just select a certain date prior to this issue.
Hope this help will help you!
Score 1
Add a comment
Add your answer
Neil Sejera will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 9
All Time: 3,666
