Repair and disassembly guides for water dispensers.
86 Questions View all
Water cooler stopped dispensing hot water Aquaverse- 7PH
I have Aquaverse- 7PH water cooler. The water coming out of the machine is no longer hot. I tried pressing the reset button and also turning the switch on off. I waited 15 mins and water coming out of machine is still not hot. Is there any way to fix this water cooler? Water comes out of cold portion fine.
Add a comment
1 Answer
Chosen Solution
Hi @fixit2000 ,
According to the service manual there may be a problem with the thermostat or the internal wiring.
Unfortunately as there is no wiring diagram in the service manual, with the power totally disconnected from the cooler you may have to locate the thermostat by tracing the wiring in the cooler and then test the thermostat with an Ohmmeter for continuity to check if it is OK or not.
Score 1
Add a comment
Add your answer
C D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 2,638
