The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
Cant get SNES to pick up on a modern tv
I have the old school SNES and the cord that hooks to tv has the one screw in cord that screws into the antenna input. I have a RCA tv model L32HD31YX13 and input is already set to antenna because thats the only tv source to that tv. There is no cable or anything to complicate it. Settings are on antenna already. If i switch SNES switch on back to channel 4 i programmed in channel 4 on tv so i turn it all on and nothing happens. But if i hit channel down it goes to 3.3 then i hit channel up back to 4 and just for a second i see mario and yoshi then screen turns blue……if i bump the channels down and up again ill see yoshi again for a second so the SNES and the cords and cartridge are all doing their job…..but i can not get the tv to allow it
Add a comment
1 Answer
Chosen Solution
Hi ,
Can’t find the user manual for your TV, but do you have to select whether to tune for digital or analogue TV channels when connected to the antenna input or does it scan through the lot, first analogue and then digital? The TV specs only state that it has a digital and an analogue tuner.
If you have to select what type of signal to scan for did you try scanning for analogue channels 3 and 4?
If you can’t get a constant signal when scanning for Ch 3 or Ch 4 on analogue then you should be able to purchase a SNES stereo audio cable - example only (scroll down the page a bit to view the cable )and connect the console to the TV’s composite input video /audio ports. (according to the specs it has these RCA input ports)
Here’s a link to the SNES user manual. On p.5 it shows how to connect to the ports. You have to change the input on the TV from the antenna to the AV input using the TV remote control.
Another alternative option is if you have an old analogue VCR and a composite video/audio cable (yellow/red/white connections) lying about, you could try connecting the co-ax lead from the SNES to the VCR antenna In and then tune the VCR for ch 3 or 4 and then use the VCR’s composite video/audio outputs (yellow/ red /white) to connect to the TV’s composite inputs.
Connect the VCR to the TV and then use the TV screen to view the VCR menu screens - you need to use the VCR remote though to navigate through the VCR You have to change the input on the TV from the antenna to the AV input using the TV remote control.
if it works with the cable or the VCR, you have both, TV channels and game console, all you have to do is change the TV input from Antenna to AV (or vice versa) using the TV remote to switch between the two.
If you do try using the VCR option, obviously it has to be powered on to connect the SNES to the TV ;-)
Score 1
Add a comment
Add your answer
Bob Stone will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 125
All Time: 12,406
