Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 Questions View all
Change the HHD to SSD
Dear All,
I do have an iMac Intel 21,5” EMC 2805 equipped with the HDD 500G (base model).
Can I change the HDD to a SSD? Specifically with Crucial MX500 CT500MX500SSD1(Z)?
do I need any termal sensor or any other adaptor? I would liketo avoid opening my iMac and then not to be able to close it…
I want to remove the HDD with a SDD not keep the HDD and add the SSD.
thanks!
Add a comment
1 Answer
Most Helpful Answer
Here’s the kit you’ll need iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit The SSD in the kit is a Crucial SSD.
Follow this guide iMac Intel 21.5" EMC 2805 Hard Drive Replacement make sure you use the correct tools and techniques outlined if you don’t you can damage the display!
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit Image
Product
$89.99
Score 1
Add a comment
Add your answer
Ale will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 102
