My headphones will not connect through bluetooth. What is wrong?
I go to connect the headphones via bluetooth and they show up in visible devices but they do not connect .
When pairing with Bluetooth it can’t connect when it is currently connected with something else so maybe you have some other device that auto connected it would be impossible for it to then connect to another so just disconnect from that device
I have a pair of wireless Solo 2’s myself, so I often run into this
Usually it’s because they are pairing to the last device they were connected to, therefore won’t let you simply connect from another phone in bluetooth settings. Imagine if some stranger tried to connect to your Beats by going to their iPhone settings… Big problem there!
To fix this, turn the beats on, then hold the “b button” (or the logo button which pauses/plays your music) for a few seconds. This should disconnect the headphone from its current paired device, allowing you to reconnect to it via your phone.
Let me know if this works!
-Alex
You are a genius, thank you so much , now i can use my beats and listen to sad songs huhu
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 997
