Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 Questions View all
Hi everyone, my Kenmore 970-c94812 stackable washer-dryer won't spin o
It starts out fine and fill with water.
However, when the wash cycle starts, the agitator won't spin, eventhough the belt at the bottom still spins (video here : https://youtu.be/SaRgXZRHPyQ).
When the rince cycle starts, the tank spins on itself perfectly. Can someone help me find out the problem? Thank you!
Add a comment
1 Answer
Chosen Solution
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Score 2
Add a comment
Add your answer
Mikael St-Pierre will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 316
