Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 Logic board not booting. DCPS shows 200 mA draw
Slightly water damaged iphone 6 totally dead.
removed the logic board, all the shields, & cleaned in ultrasonic solution branson EC, …
Found no shorts anywhere( vcc main, pp_cpu, pp_gpu, var, sdram, …). Also all the rails’ voltages seem to be in range.
Connected the Logic board only to DCPS. It does not even boot but draws 200 mA.
PMIC gets warm but not hot.
help would be appreciated!
Add a comment
Chosen Solution
Did you check ALL of the PMIC outputs or just the main ones? A faulty subsystem can pull the whole system down as well and it is often overlooked. If they all check out, then check the main subsystems that aren’t powered by the PMIc, such as MESA,CHESTNUT, BACKLIGHT. Then check the I2C lines to insure they are balanced and within range and take a look at the PMIC Reset lines (those that can be probed) to see if the problem is there.
Finally, check the BBPMU outputs as well as a damaged BB system will impede the phone from booting.
Also, what areas of the board were more corroded, that could give you some clues about where the damage actually is.
Score 2
4 Comments:
Update:
PP 1V8 SDRAM rail reads 0.52 V
by
Check that power rail with the phone unpowered in diode mode to see what reading you get. There may be a partial short that you will need to elucidate.
by
Found the shorts:
Backlight driver —> 0.18 A
U5302_RF —> 0.02 A
Both are removed.
No booting ( from zero goes to 0.12 A & repeat itself)
DFU recovery on iTune recognizes the board but haven’t gone farther. (Did not recover). Trying not to loose data.
by
PP 1V8 SDRAM. Ow reads correctly 1.8
by
Add a comment
Most Helpful Answer
Does it show 200ma when dcps is connected or after button press. If it's after button press I would check tristar
Score 2
2 Comments:
It draws 200 mA before pressing the button.
After button press just a blip & stays on 200 mA.
Could it be a faulty PMIC?
by
Before removing the pmic remove Tristar and then see what it does on dc
by
Add a comment
Add your answer
Hama will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 375
