Can I fix my motherboard?
Hi, I have a motherboard that broke 2 PSU’s, so they won’t work on another computer. Does anybody know what is wrong with it and if it is fixable?
Thanks in advance!
Thanks in advance!
Hi @random_user_101 ,
You really need to supply more information to get a reasonable answer.
Make and model number of the motherboard?
How did it break the PSUs i.e. what is wrong with them?
Are they supplying the correct voltages on all the power leads to the peripherals and the motherboard especially the 20 pin connector?
Do both PSU have exactly the same problem with regard to their output voltages or lack thereof?
Just as a guess unless the problem is obvious to the eye (simple example screw fallen across motherboard tracks or components somewhere) or you have a bench power supply so that you can start testing, which will be hard without a schematic, you might have to accept that the motherboard is irreparable.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
