Repair guides for Android cell phones manufactured by Sony Mobile and Sony Ericsson.
1302 Questions View all
Why is my K800i showing ' serious error ' on the screen?
Greetings.
I'm having issues with my k800i these recent days. I was answering a call when all of a sudden this weird message popped up on the screen "SERIOUS ERROR. STOP CHARGING. STOP USING YOUR VIDEOPHONE AND CONTACT A SONY ERICSSON CALL CENTER". From then I cannot use the phone at all. I don't know if it is a software or hardware fault. I do not know what to do. Any help will be very welcoming.
Thank you very much in advance.
Score -1
Add a comment
Chosen Solution
From what I gather it is basically the software problem so better update your phone from the sony software update center. Get the
software update for your phone www.sonyericsson.com/update to rule out software issues. I also read that some people got it accomplished by getting a new battery. It could be the battery,(clean battery contacts or better get a new one),if that does not help, it could be the battery connector on the pcb,(check for microtears, loose or corroded joints, you may consider to resolder or reflow). Hope that this is at least a start for you to get your phone back. This is where you can get all kinds of service manuals and schematics for your phone. Good Luck
Score 1
Add a comment
Hi.
Thank you very much for responding oldturkey03. You're a life saver. I was doughting it was the baterry as (often) all of a sudden, it's temperature rised ( became very hot ) and discharged. For sure I'm going to consider your advise and hopefully get the phone good and running. I'll keep you posted.
Thank you very much,
Tman.
1 Comment:
You are very welcome. All the best to you and good luck.
by
Add a comment
Add your answer
Tman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,440
