Laptop suddenly slow. Takes forever to do anything!
I haven’t used my laptop in a few weeks as I have a desktop also, however a few days ago I pulled it out to do some work. It took a while to come on and then I realised I couldn’t do anything on it, it had become desperately slow?
Ive tried:
malwarebytes full pro scan (malware/registry/free up space)
also tried the same with ccleaner
defragmented
removed and reinstalled memory/HHD
tried to install updates but its taking hour and hours without installing.
Sfc/scannow
taskmanager nothin abnormal
im at my wits end! Any help would be much appreciated!
suggest you to start checking with your hard disk first.
backup important files....
if all does not work well, consider a OS format and reinstallation.
by Augustine
Hi @kaned123
What OS is installed?
Have you tried starting in safe mode to check its' performance.
If you have 3rd party A/V software installed have you tried disabling it to see if performance improves?
by jayeff
Windows 7 professional, no third party A/V software. It runs normal in safe mode?
by Jim
Hi @kaned123 ,
Check in event viewer to see if there are any error or warning events that may give a clue as to what is happening.
Running in safe mode OK usually means that there is a driver problem as Windows loads basic generic windows drivers to run the OS or there is a startup program that is causing the problem.
You said that Task manager looked OK but did you check what programs are shown in the Startup tab and try disabling them one at a time to see if it changes anything?
by jayeff
Just noticed in task manager processes there's 'opvapp.exe' which wont let me end the process?
by Jim
Show 1 more comment
