Sensor says GPU overheating, but it's not, plus other things
It’s an iMac 8,1.
Sensor says the GPU is overheating (about 15 - 20 Celsius above what it showed until now) but it’s actually not, it’s actually really cool when you check the back case with your hand.
What might be overheating a bit is the power source, but this is located way above the GPU.
I did not pay attention to the PS temperature, before, so not sure if it is overheating, but it’s the only thing that is warm on the back of the iMac, GPU is cool, SSD is cool.
Ran an apple Hardware test and got this: 4MOT / 1 / 40000003: HDD- 1499
I did a search on that and found this:
iMac Intel 20" EMC 2133 and 2210 Hard Drive Fan Replacement
Why am I getting an Apple Hardware Error 4MOT/1/40000003:HDD-1364
Is there a 3rd HDD fan under the mobo as it seems, but not very well presented in the last 2 steps of the first link?
By the error code above does it mean that the HDD fan under the mobo is failing and that’s why the PS is getting hotter?
Why does the GPU sensor says it’s overheating when it’s not?
Update (01/22/2019)
One thing I noticed is if the screen gets put to sleep, after a while, the temperature is much lower.
I use iStat, you have a screenshot with the sensors, would TGPro give any other info besides iStat ?
Here are the temps on the "normal setting", you have a screenshot of the fan speeds at that setting as well.
Another thing that is weird is if I crank the fans does not seem to make much of a difference on the GPU temperature, unless it's 90 Celsius or so, bringing it down to about 80.
Cranking the fans makes a big difference on all other components.
So basically, GPU just sits at 80 no matter what fan speed, if I open multiple youtube windows it goes to 90, and will come back to around 80 if fans are cranked.
Update (01/22/2019)
Here you TG Pro
Update (01/24/2019)
The readings
4 Comments
TG Pro offers a bit more info iStat doesn't.
As an example a high water mark on the bar graph so we can see how hot it got, The full version also offers logging so you can plot out over time what has happened.
In any case, visually you can also see things just better comparing the sensors outputs.
by Dan
You have the TG Pro screenshot in the original question, so odd this site does not let you post pictures in replies...
by Andrei
Now let it run for a few days so we can watch the high water line on the different GPU sensors so far the Diode sensor is on the high side (this sensor is within the GPU)
by Dan
Hi @danj you have the reading as requested as an update to the original question
by Andrei
