Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
My iPhone 3G touch screen is randomly unresponsive?
Hi I have a problem with my iPhone 3g. Sometimes its hard to unlock it as the right side doesn't seem to respond so well but then other times its fine. My main problem is when I try to enter numbers on my keypad. For instance the other day the number 7,8 and 9 didn't work but then the next day they worked fine??? They have a mind of their own.
I read something about the 'grids' on a digitizer, but why would it respond one day and then the next not at all??
Can anyone suggest what i do? Should i buy a new digitizer? By the way ive opened up my phone and cleaned connections etc and checked pins and all that but still no joy? Please help!!!
Add a comment
Chosen Solution
I've seen this happen if there is moisture in the phone. Other times it happens is when the digitizer decides to go bad. I would try to change the digitizer first, and see if it still does that. It would be the easier of repairs probably.
Score 1
Add a comment
this happend to me i tried a few things,like reattaching cable 3, but this did nothing,in the end i realised that when i changed my screen i hadnt cleaned the underneath properly, once spottless my 3gs work sweetly hope this helps
Add a comment
Add your answer
Nathan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,173
