Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2693 Questions View all
Customer says phone sometimes won’t charge?
So I got this phone and they told me it sometimes won’t charge, so to change the charge port. When I first got the phone sometimes it wouldn’t charge, I took the battery out and it’s not doing that anymore but I’m hesistant to send it back until I have tested the charge port. How do i test for a faulty charge port if the phone is completely charging? If I send it back I’m hoping it won’t return to not charging when they get the phone back.
Add a comment
1 Answer
Chosen Solution
The battery is the weakest link so by changing the battery and the phone now charges correctly, you probably have solved the problem completely. You could try to overlay a replacement charge port (no need to do a full install) to see if that makes any difference.
Intermittent problems are always the worst kind of problem and the only way to know for certain is to give it time. Either let the customer try it out, under the expectation that it may come back, or have the customer leave the device with you for a few days so you can test it under several charge cycles.
Score 2
Add a comment
Add your answer
Jesus flores will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 63
