Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
iPhone 8 Home Button Really Sensitive
Hi,
I bought an iPhone 8 yesterday from gumtree, and the home button is extremely sensitive. If I touch it as if I was using Touch ID it ‘presses’ the button really quickly for as long as I hold it there. It thinks a light tap is a hard home button press.
I can use it to go home if I tap REALLY lightly. Touch ID still works.
Research shows it could be a couple things;
 - U10 Chip?
 - Bent flex cable
- Bad replacement screen
I have tried changing the tightness of the screw underneath the home button, which does nothing.
Thanks for the help
Add a comment
1 Answer
The iPhone 8 does have a more sensitive home button. Just one more of those minor irritations that life likes to throw at us. You’ll have a more sensitive touch within a day or two!
1 Comment:
Thanks for your answer but this is definitely not intended behaviour!
If i hold my finger on the button for 2 seconds as if to use Touch ID, the home button will be pressed about 15/20 times.
by
Add a comment
Add your answer
alim123 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 709
