WIfi button is greyed after replacing battery
I just replaced my iphone battery and it powers on perfectly but the wifi button is greyed out. Data is working fine as well.
Before ruling out a software issue, try resetting the Network Settings on your iPhone 6 by going to Settings -> General -> Reset -> Reset Network Settings. Resetting the network settings restores your iPhone’s Wi-Fi, Bluetooth, Virtual Private Network, and other network settings to factory defaults.
Before you do this, however, make sure you know your Wi-Fi passwords, because ‘Reset Network Settings’ will erase them from your iPhone. After your iPhone reboots, you’ll have to reconnect to your Wi-Fi network by heading to Settings -> Wi-Fi.
If the problem still exists after rebooting, you’ve possibly got a hardware issue on your hands
A grayed-out Wi-Fi button usually indicates a hardware problem with the Wi-Fi antenna on iPhone. If you’re under warranty, by all means, go through Apple!
Is there any tutorial for how to fix this issue?
You now get to know what had caused the issue?
I have already reset the network settings and even did a factory reset. I think its a hardware issue.
Really sorry for hearing that, you may need to check further into the device or get yourself a new iPhone.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 378
