I had checked with mine, and it is not easy to open.
1. From my observation, the compartment should be held with 4 screws (top) and 1 below @ battery compartment.
2. If you inspect from your picture 2, the inside screw holes, you will notice that it is the end of the screw, you can only unscrew from the top, but the top button compartment need to remove first.
3. the top button compartment (picture 4) were held with snap (click fit). It is designed a way, that when it is installed, it cannot be remove. However, you can try using a small screw to push the plastic holding to it. You can see it through from the battery connector holes. Be warned it is fragile. I had broken one, and I had stopped. I guess there are four snap in holding to it.
When you remove it, you should be able to see the four screws holding the base of the pump.
4 Comments
Hi @fah76
I had one at this at home, what issues are you having?
what information do you need?
by Augustine
Hi @salmonjapan ,
I think she means how do you openthe unit.
To me it looks like there are screws in the middle of the slots where the batteries are inserted, but I may be wrong about this.
If you have one then it will be easier for you to see if this is correct. It may be that there are tamper proof screws in there and that's why the OP is having problems.
If I'm wrong then it may be a "click fit" case of some sort.
EDIT
Looks like I was wrong about the problem but it still will need to be opened and checked ;-)
by jayeff
its not pumped the air
by Fahad
yes I want now how I open it
by Fahad
