Repair and disassembly guides for Uniden phones.
Handset doesn't charge battery or work
On returning from holiday the handset and charge base were on the floor having been knocked over by cleaners.
The handset doesn’t charge on the original base or any of the other 2 bases I have. The battery works normally however, in the other 2 handsets.
I have also tried tried my other 2 batteries in the dead handset with no result.
In summary all three batteries are in working order but none of them can operate the dead handset.
Is repair needed and/or possible?
1 Comment:
Hi @gld ,
What is the model number of the phone?
by
Add a comment
1 Answer
You could potentially have broken solder points where the battery terminals connect to power the phone itself. You could open up the phone, which are fairly easy to do as they are typically a single board with two screws holding the case closed and you can then pry the rest opening. Check the solder points on the battery terminals, it they are loose or missing you may be able to repair it by resoldering the points.
Add a comment
Add your answer
Gary Deacon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 186
