Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone stuck rebooting while charging
hello everyone
I have an iPhone 6 16 GB which suddenly stopped working
I tried to turn it on but it dint work by itself
I plugged in to charger and it has rebooted repeatedly
I have taken in to a repair shop and they said it could be from dead battery, they have changed it and it worked for an other day but suddenly it happened again with same issue
it was suspicious broken ic power but it didnt work the moment they changed that.
i heard that it could be NAND corrupted.
do yo think it could be possible that it worked for another day as i installed some apps and took some pics?
Add a comment
1 Answer
Most Helpful Answer
"it was suspicious broken ic power but it didnt work the moment they changed that."
This is confusing. It sounds like you're saying that the shop removed the motherboard from your phone and performed a microsoldering replacement of the charging IC, found the phone didn't work at all after they changed it, then...changed the IC back to the original one and put your phone back together again? That's easily about $150-$200 worth of work right there, more than your phone is worth.
Installing apps and taking pictures won't damage a phone.
Was the phone dropped or encountered water (soda, wine, etc) before this happened?
Score 1
Add a comment
Add your answer
darush kamali will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 36
