The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
82 Questions View all
DS No Longer Working After Disassembly
I decided to open up my original DS so I could clean some dust. After cleaning the dust from inside my DS, I tried to power it on but the green light momentarily powered on for a split second along with the bottom display. I then took it apart again to make sure I plugged in every ribbon cable but when I put it all together and plugged it in, there was absolutely nothing except the speaker pop when you press the power button. I plugged my DS into the wall and tried powering it on but still experienced the same issue but with the orange charging light on. Can anyone help?
Add a comment
1 Answer
Hi
i had the same symptoms with a incorrectly inserted wifi module. Have a try to unplug it and replug it
1 Comment:
You can’t remove the WiFi module on the original DS so I just unplugged and plugged the antenna to the WiFi module and it didn’t help.
by
Add a comment
Add your answer
TheLoneGamer will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 12
All Time: 119
