Want to remove 43UJ6300 series wifi board/replace it
Does anyone have a guide or some way to tell me how to remove the back cover of the 43UJ6300 series TV to get to the WIFI board.
Pretty sure my WIFI Board is dead, I can buy the part myself but can’t seem to figure out how to remove the back cover without breaking it. Any help would be appreciated.
Also wondering if the TV will still function if the WIFI board is completely removed (don’t care about WIFI really as right now I am getting “unknown device is disconnected” wish I am assuming is the WIFI board.
My warranty already gone (TV 16 months old) - taking to a service center or having someone come look at it going to cost around 150-200 bucks from contacting/looking at these prices they charge in my area.
Update (12/31/2018)
I already tried resetting, clearing the ports, unplugging the cables, updating. None works. It has to be the WIFI board as the WIFI doesn't work (it seems to be a common issue with this series of TVs after looking online) and I found other comments of people replacing the WIFI board by a tech and it fixing it. It a 50/50 as right now, I have to use "STORE" mode in order to get rid of the notifications but I can't change the screen resolution. I can find the WIFI board parts on ebay and some other sites so it seems to be separate from the main board.
If it wasn't for the "unknown device is disconnected" every few minutes, I wouldn't care as I don't use the WIFI really. If i reset, the error pops up after a few minutes with nothing plugged in. I also tried removing the batteries from my remotes to rule that out as well.
The module I found here which seems to be just a addon: https://i.ebayimg.com/images/g/cUAAAOSwc...
2 Comments
Hi,
I have the same issue! I'd like to know, where did you buy the wireless board? and if you have the number part of that board?
Thanks,
by Adrian
My 43UJ6300 was also losing its Wifi signal and in fact, wouldn't even pick up the available wifi networks when searching. I came across this thread. I followed the directions. The cover was REALLY hard to remove and I think I may have put a crack in it trying to get it off. But I finally did and I located the Wifi module. I removed it, cleaned it, tried to get the cable off but couldn't. I just tried my best to tighten the cable and straighten the ribbon. Replaced the module.
Put the cover back on and voila! It seems to be working. Thanks so much for the thread! In my case, I have no hardwire or active Ethernet cable input so the Wifi for Streaming is all I have for this TV.
Thanks again!
by NYStinger
