Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 Questions View all
How do I get cable 2 to seat?
I replaced the screen and digitizer but cant get the cable 2 to seat, therefore the touch feature does not work. It is a 3gs, only 6 months old, and the part is supposed to be for a 3gs. It seats fine, but will not stay. please help!
Add a comment
MacBook Battery Fix Kits
Starting at $69.99
Buy Now
Starting at $69.99
Buy Now
Chosen Solution
Hi Deb, are you confident the part is for 3GS? The 3GS has a black plastic piece between the metal contacts. You may have to look at some pictures to compare. If this is confirmed and the connector just won't snap into place, you need to make sure there is nothing on either connector that is in the way. Once you have the connector aligned to the one on the board, you press down. One side may go down easier than the other - press with a little force. If this does not work, don't keep forcing it - you can damage the fpc connector on the board. Patience, a couple deep breaths, and a steady hand - you will get it! I hope this helps!
Add a comment
I had the same issue as you. I thought cable 2 was OK but it kept popping off. I finally concluded I wasn't applying enough pressure. Once I did it stayed connected. I'm assuming you have the cable correctly aligned. Check that before applying more pressure. Good Luck.
Add a comment
Add your answer
deb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 695
