Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
Home button not working after screen and battery replacement?
The device was working 100% before screen and battery were replaced. After I put the new screen on with all the components the boot time increased (takes around 5 mins now) and the home button along with touch ID don't work anymore.
I checked all the flex cables and they seem all fine and front facing camera works. Tried original battery and screen and the issue still persists.
I was told that front camera flex could be the issue but the font camera fully works so can it still be that??
1 Comment
You damaged the home/Touch ID cable. See step 23 in the iPhone 7 Display Assembly Replacement guide.
iPhone 7 Screen Replacement
by
Add a comment
1 Answer
Chosen Solution
It’s incredibly easy to break the home button when doing a repair on an iPhone if you don’t have any prior experience working on them. It sounds like you damaged the home button during the repair. You may have been to rough when you where taking the home button off the old screen or you may have pinched the cable when you where putting it back together. It’s possible that you only damaged the home button extender cable that’s attached to new screen. Unfortunately that cable is part of the screen so you can’t just try a new one. You would have to try a whole new screen. You have to be super careful where the cables and connectors get seated as even a little pressure can cause major issues. Worst case scenario, you have two options. Either replace the home button with a new one and accept that fact that Touch ID will never work again or take it to an Apple store and have then replace the home button for you. Apple is the only one that can link a new home button to your phone so that Touch ID will work with a replacement home button.
Add a comment
Add your answer
Hamza will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 4,246
