Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Purchased fixit LCD need to remove frame
Purchased a iFixit LCD for the iMac EMC 2389. It does not come with the two frames on each side with the magnets. How do I remove the old one and install on the new screen?
I looked at the LCD cleanup, but that doesn't fit the model.
Need ya help on this.
4 Comments
Lets verify your system plug in your serial number (on the bottom of the foot stand) here: EveryMac - Lookup Paste the system info here for us to see and also tell us the part info you ordered (received) so we can make sure you get the correct part.
by
Apple iMac "Core i3" 3.06 21.5-Inch (Mid-2010) Specs
Identifiers: Mid-2010 - MC508LL/A - iMac11,2 - A1311 -  2389
Part I ordered:
Part # IF173-041-2iMac Intel 21.5" EMC 2389 LCD Assembly / New
by
Well, you did get the correct part!
Once you get the frame off your old panel and installed to the new panel you should be OK.
by
That's the whole problem of getting the old frame off. I got the two on each side off, but where are the others?
by
Add a comment
1 Answer
Chosen Solution
The raw LCD screen is held to the frame with four screws that on the left & right sides. You’ll need to move some of the foam away on the top two screws.
Hint: Look at the panels edge to find the screws holes two per side.
Score 3
3 Comments:
I found the four screws on each side. But others must be holding it on. Where would they be?
by
It should just come off. Carefully slice between the frame and screen with a thin blade. It's been awhile since I've needed to replace the older screens is there a third screw in the middle?
Looking at the new screen do you see more holes along the edge?
by
No third screw and no more holes. I was not slicing through the right area to release the tape. The mounting brackets have been removed. WOO HOO!
by
Add a comment
Add your answer
kneisley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 115
