My Omen Control Center Shows Cpu Usage -1% How Can I Solve?
Hi dear İfixit users,
One week ago i bought an HP OMEN , recently there is a mistake in the omen command center after set-up my printer drivers.
Omen Command Center show my processor usage -1%
How can ı fix that please help me .
Best Regards.
Hp OMEN Laptop 17 inch
17-an107nt
Bang & Olufsen
Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
16GB Ram
GTX 1050 ti 4GB
256GB SSD + 2TB HDD
2018 model
RGB KEYBOARD
Score 2
1 Comment:
Having the same issue as @berke7856 and following are the specs of my OMEN SERIES NOTEBOOK.
Bang & Olufsen.
OMEN X by HP 2S 15-dg0019tx Dual Display.
Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz.
Installed Memory (RAM): 32.0 GB (31.9 GB usable).
Installed Video Memory (GPU): nVIDIA GeForce RTX 2080 (8 GB) with Max-Q Design.
RAIDVOL - Type: RAID 0 1908 GB
[ SATA_Array_0000 PCIe SSD (954 GB) + PCIe (954 GB) ].
Model: 2019.
RGB Keyboard(Interior) & RGB Logo(Exterior).
by
Add a comment
1 Answer
What does Task Manager show when Omen CC shows -1%? If something else above 0% (as it should), then Omen CC is getting really high with incorrect use of variable types. That you can’t fix since it requires debugging the source code. Now, to be fair, I’d delete that command center (if it doesn’t allow you to do truly specific things like RGB layout editing) as well as everything else that comes with your laptop. And as a bonus, destroyed all that trash that Microsoft packs into Win 10 (like telemetry, Superfetch, Prefetch and other stuff).
If you’d like to “purify” your OS, then I’d suggest you use DWS, Win 10 Tweaker and O&OShutUp10. Also there’s RegCleaner 4.3 by Jouni Vuorio (it was free, but his site is down, so google to the rescue), that might look like from ‘98, but it works like a beast and compatible with Windows 10. And also I have a reg file that disables Cortana for good w/o losing ability to use Search Bar near Start Menu (download link: https://drive.google.com/drive/folders/1...). Blockmailru.xml is only for russian users, for you it’s not obligatory to use it.
4 Comments:
My task manager shows normal ratings at all components , there were bug on Omen CC .
I dont understand what you said about apps ,can you say more clear please .I dont want to delete or download many programs because my pc is brand new .
Note : I write the hp forum and thy allready want to help me but nothing can we do .
They said hp moderators wıll mail me and solve our problem.
by
I must use my rgb keys
by
Those programs that I'm talking about will help you destroy Windows 10 hidden telemetry (and Nvidia telemetry, too, btw) and disable forced Windows Updates (main reasons why such programs exist). Besides that they can turn off a little bit more things that can help you boost OS perfomance (by decreasing an amount of unexpected lags) or make your OS a bit more comfortable for you.
by
Ok, then don't delete Omen CC, if there's no analog for that feature.
by
Add a comment
Add your answer
Carun will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,238
