Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
How do I fix a loose CPU
I bought this phone broken, the upper part of the aluminum frame was bent a lot. So I basically bent it back to its place, swapped front camera, sensor and the upper loudspeaker. Now I am noticing that the phone sometimes gets stuck in boot loop of sorts, and if i press the spot where CPU is, it boots up normally. Usually it works for 10-30 minutes or so, and then reboots, and starts the cycle again. So I’m thinking it’s the CPU’s fault, how can I sort this issue?
I am only a hobbyist, don’t know anything about soldering, but since the phone cost me 40€, I am willing to give it a try with something I am not experienced in.
Add a comment
1 Answer
Chosen Solution
The CPU is underfilled, meaning that it is secured in place with a form of epoxy. That limits the options somewhat as you can’t just do an oven reflow because the expanding solder balls have nowhere to go and typically bridge adjacent balls or blow out from underneath the IC.
The ideal solution is a reball but that is also fraught with danger as removing the CPU can damage the pads underneath.
So theoretically, this is probably fixable but in practice there are no guarantees it will work.
Score 3
2 Comments:
Okay, well are there any guides or something I could follow to give it a try? I am assuming I need some equipment aswell? Thank you for your input.
by
You would need a hot air station, some flux and solder, a reballing stencil and solder paste etc...
by
Add a comment
Add your answer
Jere will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 137
