Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Questions View all
Home button repair and reassembly?
I have the original home button from a ipad Pro 10.5 which I need to fix onto the new screen, however not sure what needs adhesive tape applied to it.
I know the home button bracket needs tape applied to either side but do the following also need it?
  • Does the rubber gasket need tape applied to it to fix the white plastic ring?
  • Does the plastic ring need tape fitted to it so it sticks to the glass?
Add a comment
1 Answer
I put adhesive on the ring and usually the gasket around the home button will keep it in place. Once the iPad is closed the space behind the home button keeps it in place unless there is some structural issues with the iPad or the gasket.
2 Comments:
Thanks for replying... can i use adhesive tape as the adhesive both on the ring and rubber gasket?
by
Sorry for the late reply. No, just the ring. The gasket will usually stay in place with the help of the bracket that goes on the back of the button.
by
Add a comment
Add your answer
Nav will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 274
