4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Put a correct display for iPhone SE
Ok, after damage LCD of my iPhone SE broke after charge up in the car with an adapter that isn’t original, with Micro-Soldering iPhone SE has been repaired but now I need to put a new LCD with their components (home button, microphone, etc.) so I would know how can I do. I saw on eBay a webpage where there is LCD with home button, but I would know if can working with his home button and touch ID because I noticed that many times can appear “impossible to activate Touch ID”.
I saw this webpage on eBay, it’s good?
https://www.ebay.it/itm/DISPLAY-SCHERMO-...
Thanks in advance for reply.
Score 1
Add a comment
1 Answer
You can use the screen from ebay. But if you want Touch ID functionality, transfer the home button from the old display assembly. If your button is broken and you want to have Touch ID functionality, send it to apple and let them fix it because only apple can repair Touch ID. Hope this helps! Good luck!
Add a comment
Add your answer
Patrizio Masini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 53
