The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
MacBook compatible SSD conversion
Hi,
A friend of mine asked me, if a MacBook compatible SSD device can be used on any Windows laptop by using a converter. His current device has a mSATA interface only, not a m.2 compatible one. We found a converter from Sintech (http://www.pc-adapter.net/product/836.ht...), which can be used on a m.2 compatible motherboard.
He has a Gigabyte GA-Z77-DS3H motherboard (https://www.gigabyte.com/Motherboard/GA-...). He has a Samsung branded MacBook compatible SSD, which is used on a MacBook Pro 13” Retina Early 2015 version. Exact version information of this disk is currently not available. We may provide it later.
Any solutions?
Thank you…
Add a comment
Most Helpful Answer
That adapter will make the SSD work in a PC, but it never ends well going the other way and usually results in a massive performance penalty. You probably aren’t going to fare any better going the other way. Yes, the adapter will “work”, but there is a high likelyhood there will also be an associated performance penalty. You will also need an interposer since the Gigabyte board you have now doesn’t have a native slot.
These nonstandard SSD’s are intended for Apple computers. It’ll work on a normal computer with an adapter, but the historical make this a bad idea.
Your best bet is to just get a standard AHCI PCIe SSD and an interposer, since your board lacks native connectors. If this doesn’t end well the other way, what makes you think this will be any better?
Score 2
Add a comment
Hold on here! That still won’t work, as your motherboard does not have a M.2 interface only a mSATA. You’l need a PCIe card to host the Apple SSD and only the older SATA SSD will work Apple 2013-2015 MacBook Pro +Air SSD to PCI-e 1X Adapter
Score 1
6 Comments:
I was under the impression the OP understood they need an adapter because that board is too old for native PCIe SSD support.
by
The two blue slots are marked PCIe x4 and the two smaller slots in-between are marked PCIe x1. I would use one of the PCIe x1 slots for the card Mother bd image. Only the older SSD's PCIe/AHCI not newer PCIe/NVMe drives is that what you're thinking?
The other option would be a mSATA adapter but I don't know of any that supports the Apple SSD's.
by
You need chipset support for NVMe so it's only going to take AHCI PCIe without a board and CPU upgrade. I don't think you can make NVMe work on old platforms.
by
Correct! If you review this guide The Ultimate Guide to Apple’s Proprietary SSDs You'll see the Early 2015 13" MacBook Pro Retina system comes with a PCIe/AHCI SSD
by
My fear is the performance more so then compatibility. The OP knows it's pre-NVMe so we can tell him about not being able to use one of those drives; that's why I warned them that the adapters tend to slow the SSD down.
I think your solution is better, but I went with the adapter and warning because the OP seems dead set on it so my priority is to warn them. I suspect the same issue will appear with the interposer you linked.
by
Show 1 more comment
Add a comment
Add your answer
Raif Kerem Gursu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 363
