Guides and support for various television (TV) brands and styles.
9064 Questions View all
Vertical Lines JVC HD-58S998 TV No Picture
Getting Coloured Vertical Lines on my JVC HD-58S998 Televison
Problem outline:
  1. When I turn on the TV, most time I get nothing. No picture. I wait for a bout 5 minutes and the vertical lines appear. I turn off the TV, let the lamp cool, and turn it back on and picture reappears and all works fine!
  2. When I turn on the TV, no picture, no volume control showing, and no vertical lines. Turn it off, wait for the lamp to cool, turn it back on, vertical lines appear as noted in 1 above, turn off as above and picture appears / works fine.
  3. When I turn on the TV (this happened today) via HDMI 1080i no picture, but can see tv volume up and down, changed a few inputs and when I went to our Wii using RCA inputs vertical lines appeared. Turn off the TV, and turned it back on as above and TV works fine!
  4. Suggestions on what the issue could be…which part could need attention, cold solder attention etc?
1 Comment
My tv s Vizio E550i-B2 vertical line
how fix that tv I need help
by
Add a comment
1 Answer
Chosen Solution
@damirk
vertical lines can be caused by a bad T-con board or a bad main board. Start by using different video input sources and see if those lines change.
this “When I turn on the TV (this happened today) via HDMI 1080i no picture, but can see tv volume up and down, changed a few inputs and when I went to our Wii using RCA inputs vertical lines appeared. Turn off the TV, and turned it back on as above and TV works fine!” is confusing me. To clarify, you can see the menu but not the video? If so it is most likely a T-con board error.
Post some pictures of your boards, wiring etc. with your question so that we can see what you see.
Adding images to an existing question
Score 3
Add a comment
Add your answer
Damir Klobucar will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 113
All Time: 10,078
