Repair information for standalone freezers.
192 Questions View all
My mini fridge stopped cooling
i broke a chunk of ice in my mini fridge freezer area……it was packed with ice..
a huge amount of air pressure seeped out when i broke the ice….then the rest of the ice melted…..and it stopped cooling …
all i broke was ice ….
its been 4 days and the fridge wont cool again
what did i do wrong and is my fridge dead ?
3 Comments
Hi @koolpoint ,
What is the make and model number of the fridge?
Post some close up pictures of where you broke the ice off.
Here's how to do this.
Adding images to an existing question
by
thx a lot jayeff......but im gonna trash it ...
by
old turkey…..you are correct…..
i found the hole i made and considering i gotta go thru so much to fix it , ill just go buy another one….
much gratitude ……
by
Add a comment
1 Answer
Most Helpful Answer
@koolpoint it appears that you have punctured the liner. The pressurized chemical used to for the cooling of your fridge has escaped (huge amount of air pressure seeped out ). You could try a liner repair kit (search online) and then you will need a repair company to replace the coolant. For now, you might as well turn your fridge off and unplug it since you will otherwise damage the compressor further.
Score 3
Add a comment
Add your answer
POINTMAN will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 176
