Brake light won’t glow bright when I press the pedal
What would cause my brake lights not to glow? All the other lights work even all the rear but the brake lights won’t glow when I press on the brake pedal
Hi ,
It may be that the brake pedal brake light switch is just loose or mal-adjusted and not operating correctly or it is faulty.
This link may be of some help
Check your brake light wiring ground. Or, check the bulb socket for corrosion
or check the bulb socket for corrosion
Where would the ground be located
It’s a 2001 if that would help
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 659
