Why is my Washer making a draining noise
Our washer timer button doesn't shut off after the clothes are spinned dryed. There is also what i believe to be a slow draining noise from the washer that we can't stop. There is no water in the tub. So i don't think it's a leaky pipe. And there's no water anywhere else. I did pull it out and checked the hoses for clogs. Nothing but water came out.
Score
0
Hi,
What is the full model number of the washing machine?
Is the draining noise there when the washer is still spinning or after you have stopped it?
If still spinning have you checked what is coming out of the washer's drain hose?
Have you shut off the water supply taps to the washer to listen if the draining noise stops?
by jayeff
