Hi,
I couldn’t find any info regarding the value of the component, but I’m hazarding a guess as to what it may be.
I found this image of a similar RAM module (not Crucial but hopefully the same layout) where I suspect that the component may, stress may, be the same as 3 other components, or at least the same as one other that I marked on the board.
(click on image to enlarge for better viewing)
I have underlined a pattern which shows up twice on the board and boxed the components (one of which is the missing one) which I believe may be all of the same type and value.
You may wish to check this out on your particular module and see if it appears to be the same.
If it does appear to be the same and if the shown boxed components are identically marked as to their value it may be that the missing one is of the same value.
Again, this is only a guess and hopefully someone else may have a more definitive answer.
If no one else knows it still may be good to consider as a fallback option.
2 Comments
Hi,
Have you got another identical RAM module that shows the component (how do you know that it is a capacitor?) which perhaps shows any markings on the component?
Cannot see to well on the pictures but are there any markings next to the solder pads on the board which may help to identify the type of component that it is, e.g. C something or R something or even F something?
by jayeff
I k ow it's a capacitor because I saw it on the internet called MLC but I don't know the voltage and stuff
by Troll Master
