SONOS PLAY 5 is the original, bigger room, bigger sound, all-in-one Sonos music player.
Sonos Play 5 fails to turn on.
One day my Play 5 died. I suspect the pcb fuse next to the power terminal; however, that usually leads to a diode downstream being blown as well. As I can find no schematic of any kind, I hesitate to operate on this corpse without some encouragement and hopefully a tip as to which diode to test.
There is a Play 5 teardown section, but nowhere to select it in the drop down “Choose a Device”.
Score 2
Add a comment
1 Answer
Chosen Solution
Hi @a1tinman ,
Presumably you have already opened it up and checked that the power is getting through the power board to the power board outputs. If not, you may have to trace it forward from the power input socket to find out why not.
This is difficult without a schematic but unless you can spot an obvious problem, heat stressed or burnt components or blown (or bulging) capacitors etc, then point to point testing with an Ohmmeter, (disconnect the power) or a Voltmeter (if you know what you’re doing - be aware of lethal voltages etc), and drawing a copy of the circuit as you go, is the only way to find out what is happening.
Score 3
Add a comment
Add your answer
Paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,894
