The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Using display to display other stuff!
I've dismantled my tab3, not really worth keeping around but i'd like to know if i can use the display to display other stuff! The plan is if yes to wire it and make a wii portable but i've no clue how to wire it and if i even can
A pointer would be helpful!
Add a comment
1 Answer
Chosen Solution
Ben Lang  you could with some extensive knowledge of circuit design and PCB construction. you will need a driver board to hook it up to anything else. With the case of your idea, you would need to know the output data from the Wii’s display adapter and you would need to have the input data for your Tab3 display. Without having this data etc. (in most case even with all that data) it is pretty much impossible for the normal DIY’er to do this.
Score 1
Add a comment
Add your answer
Ben Lang will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 22
All Time: 188
